Home Theater Forum  ›  Forums  ›  Other Diversions  ›  Computers and HTPC  ›  Help please
Help please
#1
Rating: 0
I am having issues connecting my 52 inch sony xbr-6 to a HTPC; I previously had it working fine but the old PC failed and now, the only way I can get it to work is to start the pc with the video connection to the PC disconnected. After the computer boots up I can connect the tv and all is fine. The computer hangs up on the boot screen if left connected during startup.
The old computer was AMD based with 2 nvidia 7600GT's in SLI; the new one is an intel based quad core with a single nvidia 8800GTS. Both machines are custom builds of my own creation. Both machines ran Windows XP.
I use a DVI to HDMI adapter with a dvi cable; I have also tried an HDMI cable with an HDMI to DVI adapter with the same results.
Anyone ever hear of this?
Export to Wiki
#2
Rating: 0
If you still have the older 7600s try putting them into the computer. double check the 8800 is installed properlly, with a power supply that can handle it. thoughs are my suggestions
Export to Wiki
#3
Rating: 0
Probably a driver issue.  Get the latest drivers for your card.
Also, monitor the boot process to see what kills it.  F8 during POST, select Enable Boot Logging.  It will write to a file called Ntbtlog.txt in your system root.  You can look at this and see where the problem is. It should also display what is being loaded on the screen so you can see where it hangs live.
Export to Wiki
#4
Rating: 0
You may also want to update your BIOS and make sure your boot order is set to boot from the Hard Drive first.  I haven't seen this particular issue but I have seen where even having an external hard drive installed via USB, will make a Windows XP box hang on boot.  Fixing issues like this in the BIOS usually does the trick.  And yes, definitely update your video drivers.
Don
Export to Wiki
