Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Speakers and Subwoofers  ›  Wiring 2 subwoofers in a 7.2 system
#1
Rating: 0
 I have a little question:
 I  am using twin 10" uber subs from orb audio front and rear, Would you still use Y splitter to get both R and L in the mono line or single input into each, say front is right and left is rear?
Export to Wiki
#2
Rating: 0
Welcome to the forum.
There is no .2 only a .1 no matter if you how many subs you have.  It is how many independent sound channels you have.  Also, there is no left or right for subs, just an LFE/sub output.  Use a Y to split that single output to two and run it to each of your subs.
Export to Wiki
#3
Rating: 0
Which receiver do you have.  Some have 2 or 3 sub pre-outs.  Some of those work independently to allow different trims and distances.  Depending on which model you have, the answer could be different.
PS - I should add that working independently only for setup, they still carry the same signal (as Robert said, .1 only).
My Home Theater
Our DVD Collection
Dolby and DTS Plaques (downloads)
Export to Wiki
#4
Rating: 0
 Well, thanks for the info the subs came today and I don't need the Y, they are single inputs only anyway..
Export to Wiki
