hello, i am hoping someone has some ideas of experience
So i converted my garage to a theater room.
My house is 20 ft from my Neighbours bedroom. They call us and complain if we are watching a movie with lots of bangs/explosions.
So i looked at the wall that us separating us.
it is just a normal garage wall , with siding-->that blue foam panel--> some cheap insulation and then drywall on the inside.
So am looking for some ideas
i did a little google'ng .
I am wonder if someone has done something simular and if it worked.
I really can not alter the room on the inside. It is completely finished.
so here are a couple of options that i have found
http://www.foampower.com/store/two_component/slow_rise.html
pretty expensive (going to be about $700)
or this may be an option, if i take down the siding on one wall and place this stuff and then put the siding on top of it
http://www.soundisolationcompany.com/sound-solutions/walls/barrier/
Thanks for any suggestions
