Here is a good place to start looking at turntables:
http://www.needledoctor.com/Online-Store/Turntables;jsessionid=0a0108431f43eab8922133c545028d7d94df08dd486a.e3eSbNyQc3mLe34Pa38Ta38PbN90
As you can see, turntables can cost into the thousands. Those with real wood, tend to run a little more expensive, than a lot of them. I'm sure he'd be happy, even if his new turntable didn't have wood. You may have noticed that some of the most expensive TTs don't have wood. You may also be able to get a very good deal on Craig's List, for a good vintage TT, possibly with wood. A lot of people prefer the vintage turntables. Something like this?
http://raleigh.craigslist.org/ele/1377853430.html
or this:
http://raleigh.craigslist.org/ele/1361639019.html
As far as features, they don't have a lot. I'm not an audiophile, so they may have more than I realize. They are usually either automatic or manual. Real audiophiles usually prefer manual. I, personally, like a cue lever, to set the needle onto the record. My hand is so shaky.
Good luck with it................
Samsung HL61A750 (LED DLP) Onkyo TX-SR805
Oppo BDP-83 Blu ray Polk Audio LSi9
Polk Audio LSiC Sony SS-MB100H
JBL PSW1200 (Sub) ...
I don't think Crosley is what you're looking for. They are just ok, and serve a different purpose than what it sounds like your boyfriend is looking for. It doesn't sound like he's looking for a USB turntable either. Sounds more like he's looking for a Denon, or something nicer (Rega, Thorens, etc.). Whatever you decide on, remember to see if a cartridge comes with it. Cartridge is extra with a lot of them, but necessary.
Quote:
Originally Posted by
helpmeplz09
He has mentioned before that he would like a
nice turntable...record player...same thing?.....that has a nice wooden enclosure. He has mentioned that something like this would run a few hundred dollars.
I promise you he's not talking about a Crosley...............
I'd almost bet he's talking about something like this:
http://www.needledoctor.com/Thorens-Turntables-TD-240-Cherry-Veneer-Finish?sc=2&category=355
and just doesn't realize how much it costs.
But I guess you know him better than me. Good luck!
By wooden, vintage style enclosure, I'm betting he meant one like I linked to earlier, on Craig's List:
Like I said earlier, check your local Craig's List. If you can find one in good shape, like the one in the link, put a new belt and cartridge on it, he'd love it. I bet he'd even like one without the wood, to get by with. Then you could both keep your eyes open for a good one on Craig's List. You might could even get a good deal on one of the real expensive ones.
Where are you located? I see it's not listed in your info...........
If has to have a wood enclosure, although I'm not sure why it would have to, how about a vintage Dual?
Another option at a lower price point (relatively) is on of the top of the line Denon's.
www.needledoctor.com/Denon-DP-500M-Turntable
This deck has gotten quite nice reviews over the years. New price runs around 700, but there are some used and.or refurb units available on Ebay for around $450.
"I sit in my cube with my headphones on and try to let my competence hold back the tide for as long as possible, then move on when the flood of stupidity breaches the levee. I'm a refugee from Hurricane Stupid."
He may actually be looking for something like the little Crosley nostalgia units, they are very cool. What kind of "stereo" does your boyfriend have now? Does he have a home theater system with some components and speakers and a subwoofer already? Knowing that would help us out a lot. If he has a "stereo" system to plug a turntable into, he would probably love the Denon at Needle Doctor has for about $300.
http://www.needledoctor.com/Denon-DP-300F-Fully-Automatic-Turntable?sc=2&category=46 It's a good quality turn table at a very reasonable price.
If he doesn't have a "stereo", check into the Crosley units, buy the one you like the look of and make sure to tell him that he can return it if he's after something else.
Philip Hamm
Moderator Emeritus
It's possible, but I took it for granted he wanted better than a Crosley, because she said "He has mentioned that something like this would run a few hundred dollars." I consider "a few hundred" to be more than the price of a Crosley.............. I could be wrong though.
That will definitely be better than the Crosley.
I think though that it's meant to be a DJ turntable, since in the name it says "Professional" stereo turntable. I'm sure your boyfriend will be much happier with that one.
The Crosleys are ok for people that don't really care how good they sound, as long as they can play their records. You'd be amazed at how many people are like that. Afterall, look at how many people like mp3s. You can record your album onto a cd on most of them. They sell them here at Belks. If you have a Belks store near you (Belk, Belk Tyler, Hudson Belk, etc.), you can go see one. They may have them at Target also.
Since you said he had a pretty nice system, and wanted one for a few hundred dollars, I was pretty sure he wouldn't like the Crosley. Glad you've found something else.............
Good luck!
The Audio Technica turntabe you are considering has a very good reputation. Highly recommended.
Philip Hamm
Moderator Emeritus
