JVC UNVEILS SUPER-SLIM GD-32X1 32-INCH LED MONITOR WITH
INNOVATIVE DESIGN AND FAITHFUL COLOR REPRODUCTION
WAYNE, NJ (September 23, 2009) – JVC Professional Products, division of JVC U.S.A., today announced its new GD-32X1 32-inch super-slim flat panel HD monitor. Just 1/4-inch thick at its thinnest point and weighing only 12.5 pounds, its produces vivid images with faithful color reproduction while using fewer materials to minimize its impact on the environment.
Even with its thin, lightweight form factor, the 16:9 monitor is durable enough to be mounted on the wall (or hung from the ceiling) in stores, businesses, and academic institutions. A variety of professional preset modes makes the GD-32X1 an ideal choice for digital signage, professional photography, general medical reference, and CCTV HD and SD surveillance applications.
JVC has designed an original LED edge-lighting system for the GD-32X1 that delivers uniform brightness and light efficiency with a 178-degree viewing angle. It features full 1920x1080 resolution with a 4,000:1 contrast ratio, and provides 90 percent coverage of Adobe RGB’s wide color space.
With its Intelligent Color Management, the GD-32X1’s picture engine analyzes color distribution in each frame of the input signal in real time for precise processing that results in images with more realistic colors and textures. High-speed Intelligent Gamma Adjustment improves contrast, particularly in scenes with light and dark areas. Intelligent Clear 3D Noise Reduction detects and reduces picture noise without motion blur, while 100Hz/120Hz Clear Motion Drive III technology uses a 3D real-time noise reduction system to significantly reduce motion blur.
The GD-32X1 It also offers a variety of inputs, including analog RGB, component/composite, and two HDMI ports. Plus, it includes SD/SDHC card and USB slots for viewing photos, as well as RS-232C connectivity and a stereo 3.5mm mini-jack. An optional speaker unit (TS-C32SPG) is also available. The GD-32X1 will have a suggested list price under $3,000 and will be available in November 2009.
