Home Theater Forum  ›  Forums  ›  Home Theater  ›  Basics  ›  Using TIVO remote for TV and Home Theater
#1
Rating: 0
I have a Samsung LED TV (B6000) and a TIVO HD XL.  The TV audio is not great and I need a Blue Ray player anyway so I am planning to buy a "home Theater in a Box" with built in Blue Ray.  My highest priority is to be able to continue using the TIVO remote for everything except the DVD.   (Control Power on/off and volume)
Does anyone have that setup and have recommendations.
Thanks, John
Export to Wiki
#2
Rating: 0
TiVo remotes have very little control other than a TiVo and a TV.  Look into the Harmony remotes.  I picked the 880 model because is had a TiVo 'peanut' shape.  It controls 20+ pieces of equipment with 16 activities on a color LCD screen.  If it is out of your price range there are other, similarly shaped Harmonies that are less expensive.  I wanted full control over the descriptions of my activities because I have three high def DVR's in my system.
Export to Wiki
#3
Rating: 0
I should have been clearer.  I really like the TIVO remote. The TIVO remote according to the instructions can be set to  control volume and mute for a home theater.  But it doesn't mention power on/off. TIVO supports Dolby Digital  The Samsung TV supports AnyNet which I understand is their name for HDMI-CEC which allows HDMI devices to communicate (power on/off)
So it seems like I might be able to use the TIVO remote to turn on/off the TV/HomeTheater and have the remote control the audio volume on the Home Theater and get the 5/1 digital audio. All with only the TIVO remote
BUT does it really work that way?  I was hoping that somebody has successfully setup a similar system (or tried and failed)
Thanks for any advice.  John
Export to Wiki
#4
Rating: 0
If all you want is control of power and volume, follow:
http://support.tivo.com/app/answers/detail/a_id/278
It will work fine since you have learning on the Tivo "glo" remote.
A Harmony universal, however, would control the DVD as well, and automatically switch inputs on both the TV & receiver for you.  As is, you'll have to switch the HTiB input with the HTiB remote, then the TV input with the Tivo remote, every time you switch from DVD -> Tivo.  Though if this isn't that often, then maybe it's not a huge deal to you.
Also, consider separate components instead of HTiB, the speakers will be much better usually.  Good receiver + speakers can last a very long time, the better sound quality is worth the extra cost IMO.
Export to Wiki
#5
Rating: 0
Thanks, I now see how to program the remote to have the power button turn on 2 devices.  Although I am concerned about the problem of the buttons getting out of sync.  I guess that happens when the 2 devices have different sensitivity to the infrared.   I assume that having the infrared port on the TV and HBiB near each other would minimize this.
I am weighing the tradeoffs between HBiB, sound bar and components.  cost, space taken up, complexity, and audio quality.   We have a small living room and 60 year old ears so audio quality is not as important as it might otherwise be.  We mostly just want to be able to understand the actors when they mumble.
Export to Wiki
#6
Rating: 0
If I was to buy a Samsung HTiB with 1 or more AnyLink HDMI-CEC inputs and 1 HDMI-CEC outputs shouldn't the following work.
HDMI cable from TIVO out to HTiB in
HDMI cable from HTiB out to TV HDMI in.
The TIVO HD remote would control power and volume for the HTiB and the signal for the TV power would be carried from the HTiB to the TV via the HDMI cable.
It appears that 1 or more people have gotten this to work with all Sony components with TheaterSync which is their version of HDMI-CEC.  I wonder if one can mix brands if the control protocol is standard.
Export to Wiki
#7
Rating: 0
Yeah, that would work.  Only the top of the line HTiB will have HDMI *inputs* though.  The cheaper ones only have outputs for their DVD/BD players.
HDMI-CEC is intended to be cross-brand compatible, but there can always be implementation bugs.  Shouldn't need it too much in this situation.
Even with good speakers sometimes one can have trouble understanding actors at times ... my approach is to use the instant replay and turn on subtitles/captions.
Export to Wiki
#8
Rating: 0
Stephen,
Thanks for all of your input (both in this thread and other s)
I am seeing what you mean about availability of HDMI inputs.  My previous list of HTiB candidates all had none.
It looks like a universal remote may be cheaper but I love the TIVO remote.  It is a beautifully designed human interface.   I might end up spending more than I planned.
Hmm, I guess this is an important question.  I was assuming that the center speaker would be mostly voice and with separation from background noise it would be easier to understand.  Maybe not.  It is hard to test this in dealer showrooms.
Export to Wiki
#9
Rating: 0
Quote:
Originally Posted by jthomas119 View Post
Stephen,
John,
Check out the Harmony 670:
www.amazon.com/Logitech-Harmony-670-Universal-Remote/dp/B000IMSK8Y/ref=sr_1_6
It was specially designed for people with TiVOs and other DVR's.  All the recording buttons (FF, REW, Pause, etc.) are grouped around the middle for easy access.  If there is universal agreement (or near agreement) on any product here at the HTF, it is the Harmony brand of remotes.  They are simply years ahead of most (all) remotes out there.
As far as the speaker clarity is concerned, a surround sound setup will allow you to calibrate the sound so that it is balanced and distributed properly between the speakers.  Some people find that after calibration, a bump or two in the dB output of the center speaker can make dialog clearer.  This is something you can't get with standard TV sound.
Export to Wiki
#10
Rating: 0
Update.
I did finally settle on buying a Samsung BD1250 and a Harmony 670.   I am fairly happy with the 650.  It took longer to setup than it should but that was partly my fault.  My biggest complaint is that it is hard to read the LED screen when it asks you questions to get back in sync.  Also it seems to often get out of sync on the proper HDMI input from TiVO.  It seems to know that it needs to change the input but doesn't do it correctly.
Export to Wiki
#11
Rating: 0
My HDMI is kind of flakey when I first turn my system on.  It always defaults to the last HDMI input no matter what activity I choose on startup.  I just wait until everything is properly powered up and choose the same activity again and it syncs up everything.  I have only used the Help screen on the remote once and it screwed up things so bad that I had to re-program the remote.
If you are getting out of sync because some equipment is missing the IR signal, remember to point the remote at the equipment as long as the transmit icon is on.  It takes some time to learn this.
Export to Wiki
#12
Rating: 0
You can also set the order of startup in the Harmony advanced setup (under 'Troubleshooting").  Sometimes HDMI requires the TV be on before everything else.
Export to Wiki
#13
Rating: 0
Some things to try for better Harmony operation:
adjust the power on delay for the TV, long enough for it to reliably respond to input change requests
(devices/more options/adjust delays)
(adjust inputs):
if possible use "discrete codes" for input changing, "method 2", one button for directly going to an input, rather than one of the other methods.  Use the device mode for your TV, see if it has commands for jumping directly to an input.  Sometimes you need to enter a slightly different model # (different size, sometimes older/newer series).
Do the same for power commands (separate command for "on", separate for "off", even if your original remote doesn't have it, there may be codes that work).
Export to Wiki
