So, I have a 52" Samsung Series 5 hanging off my wall from two studs using a SANUS wall mount that has an extendable arm to pull the tv out from the wall like 20" or something. I have two lag bolts on each side of the moutn going into two studs.
So far everything has been solid and I am pretty comfortable with it on the wall. I rarley pull it out from the wall, partly because I dont see the point and partly because I dont trust pulling the tv out that far and it not rip out from the wall or something.
My question stems from the fact that I have built a custom shelving unit out of 5/8" MDF that is going to float off the floor and hang off the same wall just under the TV. I plan on lag bolting it to three studs on that wall, two of which are already supporting the above TV. This shelf will only hang from the wall no feet. The unit weighs 60 pounds right now sitting in my garage and is about 4 feet long. Obvioulsy more when I throw the TV box, DVD player, receiver and Xbox on it.
Think this is to much for the wall. I am thinking it might be better to install legs and not mount it to the wall afterall.
Thoughts?
Edited by libtech - 8/15/2009 at 06:01 am GMT
