I'm trying to get the highest possible resolution from my laptop into my monitor, and eventually into a hdtv. Here are the details of how I plan to do this - my laptop has only a VGA out, but according to the graphic card specs, it has the ability to use a component adapter, which can be set to different HD resolutions (link below), so I plan to run a component cable from that adapter into the component in on a Pioneer VSX-919AH-K receiver, then go from the hdmi out of the receiver into a samsung 2033sw computer monitor with a hdmi to dvi cable, and then eventually a hdmi to hdmi cable to a hdtv being according to the receiver specs it has Analog to HDMI Video Up Conversion, hoping that I will get the best resolution and ease of hook up possible from this laptop. Thoughts? Also if that method through the receiver will not work, my second plan of action is to buy a component to dvi cable and run that from the adapter straight into my monitor. will any of this work, any thoughts on my process?
The audio will be run from an optical out of my sound card into the optical in on the back or the receiver.
I will also be running a digital mixer into a digital in on the receiver while trying to have the monitor still on, will this work?
At times I will want the audio the receiver plays to be from the optical in with the monitor on, and then other times the audio from the digital coax in with the monitor still on from the PC. Will this work?
www.newegg.com/Product/Product.aspx
www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/PioneerReceivers/ci.VSX-919AH-K.Kuro
