Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Audio/Video Sources  ›  7.1 hd ma sound ?
7.1 hd ma sound ?
#1
Rating: 0
Hello,
 This is a first time post for me and I am not really an audiophile!
 I have a Sharp BD-HP20u player that is supposed to decode all the  new
sound tracks DTS 7.1  HD MA etc. It is connected to a Denon 2808 CI
reciever via 1.3 HDMI. The BD player has no multi channel outs.I have installed 2 Boston rear back speakers to get 7.1 surround.
My Question: I insert a movie and choose the audio setup for MA HD 7.1.
When the movie plays the display on the Denon says DTS surround and the speaker display shows only 5 speakers working and the back rears output nothing.I have read the manuals for both pieces and can not figure it out.I would hope that someone on this forum could give me a few ideas. Thank You
Export to Wiki
#2
Rating: 0
If the speaker display is only showing 5.1 speakers working, that's the signal it's getting. What movie is it? You sure it has a 7.1 soundtrack? Just because you have 7 speakers connected, doesn't mean you'll hear 7.1 surround. Are you bitstreaming from player to receiver? If it's a 5.1 signal, you can set it to use Dolby Pro Logic IIx, and it will divide it up, to use the 7 speakers. Not very many movies have an actual 7.1 surround soundtrack right now. More info might help us figure it out............
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
JBL PSW1200 (Sub)                        ...
Export to Wiki
#3
Rating: 0
Hi,
Thanks for responding.
 I don't remember the movie titles but when I went to the setup menu it would allow me to choose 7.1 MA HD. Yes I am bitstreaming from the BD player.I would think that using Dolby Prologic IIx would not give me the same sound quality. Is that correct?
Export to Wiki
#4
Rating: 0
I doubt it will give you the same quality sound as dtsHD Master Audio, but the only place to get that is from blu ray. I mentioned that just to tell how to send a 5.1 signal to 7 speakers. It will also take a stereo signal, and send it to 7 speakers. So, you may like it for tv and regular dvds.
The 2808CI is supposed to decode the HD audio, from a bitstreamed signal. It's got to be a setting somewhere in the receiver's setup menus. I'm not familiar with that model, but I'm guessing that somewhere there's settings to tell it how to handle the signal it gets. All I can say is to double check the manual, and see if you missed something somewhere.
Maybe someone with the same receiver will chime in, and be more help.
Good luck!
Export to Wiki
#5
Rating: 0
Quote:
Sharp BD-HP20u player that is supposed to decode all the  new  sound tracks DTS 7.1  HD MA etc
Is it possible to return for a different player?  If this model # is accurate, unfortunately it's an old model that does *not* support DTS-HD/MA at all.  Either decode or bitstream.  It's also slow as hell to load discs & operate (my mother got one of these free with her TV, I cringe when I use it, although the audio isn't an issue on her 3.1 setup).
Export to Wiki
#6
Rating: 0
Here are the specs from Sharp:
Format
MPEG2/H.264/VC1 Yes
AC3 Yes
DTS Yes
Linear PCM Yes
DTS HD Yes
Dolby® Digital Plus Yes
Dolby® TrueHD (Lossless) (48kHz) Yes
 If this is not what we are talking about then could someone tell me what BDplayer would be the best to buy for 7.1 HD/MA?
Export to Wiki
#7
Rating: 0
Anything newer will support 7.1 DTS-HD.  Out of the current crop I'd probably go for the LG 370, or the LG 390 if you prefer wi-fi, for fast loading times + Netflix.
Export to Wiki
