I purchased this case from Newegg.com to round out my recent HTPC build. I bought this version from nMediaPC because of it's full ATX form factor and it's feature set.
The case is primarily...
A dysfunctional family heading home for the Christmas holidays is a familiar cinematic theme (think The Family Stone as a recent American example), and this scenario forms the basis of Arnaud...
Studio: Acorn Media Group
Rated: NR
Film Length: app. 468 minutes
Aspect Ratio: 1.85:1 (enhanced for 16:9)
Audio: English DD 2.0, English DD 5.1
Subtitles: English SDH
MSRP: $59.99
Package: Box with...
so i purchased a 3-gang 7.2 wall plate from monoprice. i found a 3-gang box at Home Depot but it seems the wall plate won't screw to the box. can any of you give me a link on a site that sell these boxes? thanks in advance!
NEMA is short for national electrical manufacturer's association, or something similar. It should be that all the electrical boxes in the big boy's toy stores or hardware stores are the same - I'm surprised that the wall plate does not fit it.
Normally, the elctrical box goes in the wall, then something is screwed into it ( switch, outlet, phone jack) and then a cover plate screws into the (switch, outlet, whatever) Blank cover plates are made to screw right onto the lugs in the box.
Perhaps there is some sort of adapter gizmo that can screw to the box, then the plate will screw to the adapter. You can find exactly that at Home Depot, Lowes, and Ace hardware. It looks like a flat piece of metal with holes in it, usually curved side-to-side to leave clearance for whatever you might have attached to a cover plate.
chuckg,
thanks for the quick reply! that does help! that's what i thought as well. i guess it's called a 3-gang "mounting bracket"? if so, i couldn't find that at my local home depot. mayb i'll try lowes.
i used a 3-gang box from home depot. any 3-gang box will work, just make sure it's rated for low voltage. the 7.2 wallplate from monoprice will fit. you'll have to unscrew the faceplate from the speaker terminals. then use the supplied screws to screw the 3 speaker terminals to the 3-gang box... and that's it. i originally thought the faceplate will screw into the gang-box. let me know if that makes sense....
Martin Luther observed that the human race is like a drunkard who falls off his horse on the left and makes up for it by falling off the next time on the right.
