Bleeding obvious question here: what is your setup, and what are your settings?
\"My opinion is that (a) anyone who actually works in a video store and does not understand letterboxing has given up on life, and (b) any customer who prefers to have the sides of a movie hacked off should not be licensed to operate a video player.\"-- Roger Ebert
RAF
- Robert A. Fowkes
- offline
This may or may not help. Now that I've moved my PS3 out of my HT into another location in my house (my new Oppo BDP-83 is now my HT Blu-ray player) I've noticed something "strange" about the audio on the PS3. When in the theater, my PS3 was connected directly via HDMI to my Denon AVP pre/pro and the audio settings on the PS3 setup menu were set to "Auto" (meaning, I gather, that somehow the PS3 would send the proper audio signal and format to the AVP via HDMI). It always worked like a charm with zero problems. Now that the PS3 is no longer my primary Blu-ray player and is no longer connected to my Denon I experienced a similar situation to what was described by the initial poster. I just got a new Mitsubishi Diamondvision 65" 1080p DLP RPM (Model WD65837) and was running it through its paces outside the HT while waiting for the stand to arrive (tomorrow). I wanted to see how 1080p looked so I connected the PS3 to the new monitor via HDMI. Granted, not the same audio as what I'll have in the main room, but I was more interested in the picture at this point anyway since audio will not be a problem. I started watching the Blu-ray version of Sweeney Todd (5.1 DTS sound) and immediately noticed that I could hear some of the people who were singing, but not all of them. The opening scene has Johnny Depp singing with the young sailor and I could only hear one of them although the both clearly were singing according to the picture. I finally figured out that I was only hearing some of the 5.1 tracks and not all of them. I suspect that's why you are hearing "thoughts" and not all the sounds you suspected would be there. I knew that the Monitor was set up to received 5.1 sound (my choices are "stereo" and "surround") so I looked a little further. When you go into the audio systems settings on the PS3 menu you can either choose "auto" or "manual." In "manual" you select various sound options from a long list, checking as many as you feel are appropriate. I chose all of the surround modes as well as stereo, figuring that if I did that then the sound that I chose from the DVD menu would get through. Lo and behold, it worked like a charm. My conclusion from this is that depending on what equipment you have your PS3 connected to, the "auto" audio setting may or may not work. To play it safe, switch to "manual" in the PS3 audio menu and check off all the codecs you might encounter. That should do the trick if your situation was in any way related to mine.
I hope that this helps.
RAF [
Demented
Video
Dude since 1997]
[Computer Maven since 1956]
["PITA" since 1942] CLICK HERE to visit My HT HTF Rules and Regulations
