Re: Entry level Reciever.....
Quote:
Originally Posted by MarvinJr
But I still need to keep the dish network reciever connected to the tv via the f-type connector right?
No. You'd be watching the TV on the composite input. That connector is for watching satellite on channel 3/4.
Quote:
| Because by connecting the composite video from reciever to TV that is just letting the signal from the dvd and playstation get to the TV thru the reciever? correct? |
Yes, plus the satellite.
Quote:
| Also which plugs would I plug the playstation into? I don't have an MHDI cord at this time, but the plug from my playstation is an HMDI into a component plugs (? the red, white and yellow ones) |
I'm going to assume your playstation is a PS3 since you are talking about
HDMI. But if you have a PS2 my comments still pretty much hold since you aren't using HDMI.
Since your TV doesn't have HDMI, and your receiver can't do anything with the audio, you should ignore HDMI completely.
You need to get your terminology straight regarding "component".
"Component" is a video connection using 3 jacks/cables marked green/blue/red, usually labeled "Y/Pb/Pr". It is used on newer video equipment and HDTVs. These often are also grouped with a pair of red/white jacks for stereo audio; you can find cables that are just the 3 for video, and also 5-RCA cables that have 3 for video + 2 for audio. I think you are getting this mixed up with the older audio/video "AV" inputs/cables, the yellow/red/white jacks which carry "composite" video, and right/left stereo audio respectively.
Since your TV is an old std TV, it doesn't have component, it only has an AV input, and apparently mono not stereo since it only has one audio jack. You need to use the "AV" cable that came with the playstation. One end is a proprietary end that sticks into the game console's "AV multi out". The other end will have the yellow/red/white AV cable. You'll stick that end into an input set on the receiver. In addition you'll connect the optical from the playstation to the receiver.
Also note that the "AV multi out" is not the same as HDMI. It's a proprietary connector only found on playstations. PS2 only has this, the PS3 has one of these plus a separate HDMI jack. They are perhaps similar size but different shapes/pinouts and are not at all compatible.
