Home Theater Forum  ›  Forums  ›  Home Theater  ›  Basics  ›  Samsung DLP Color Issues (Help Needed)
#1
Rating: 0
Hello, I am having trouble with my Samsung DLP TV (HLR4677W).
Here is the issue that has been happening consistently for about 1 week:
The TV will run fine for ~30 minutes. After ~30 minutes the picture starts flickering and then the colors get all "messed up" (it looks blurry, with limited
colors, and similar to "pop art" posters). Once this issue kicks in, it impacts all inputs (HDMI, component, AV, basic cable, etc).
If I turn the TV off at this point, it will not come back on. It tries to cycle on several times before shutting down, but a picture will not show. If I
give the TV about 15 minutes, it will come back on, but I will start experiencing the same problem (usually within ~5 minutes).
I've tried a couple things with no luck:
- I made sure that the TV is plugged directly into a wall outlet to ensure proper cooling.
- I placed a large fan behind the TV to see if it would resolve a potential cooling problem.
- The lamp is only 1 month old, so this would only be a problem if the replacement lamp is defective.
I've read up online and I am questioning if this could be a color wheel problem, but these I haven't found matching symptoms yet. Any help would be greatly
appreciated.
Thanks!
Export to Wiki
#2
Rating: 0
Re: Samsung DLP Color Issues (Help Needed)
It sounds like you need to return it for an exchange..........
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
JBL PSW1200 (Sub)                        ...
Export to Wiki
