Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Receivers/Separates/Amps  ›  ohm vs. watt question
#1
Rating: 0
thinking of upgrading my receiver. the receiver i have now is rated at 130w at 6ohm and the one im looking to buy ia 110w at 8 ohm. my speakers are rated at 250w at 8 ohm. would i be improving my sound or not?
Export to Wiki
#2
Rating: 0
Re: ohm vs. watt question
What models and numbers? Some times receivers are rated @ 6 ohms to advertise a higher power rating. In any event, power ratings on receivers and speakers are really not as important as many people think. There are many much more important things to consider.
"Everyday room": Mitsubishi 52631 RPTV, H/K 520, H/K dvd-5, H/K 8380, H/K CDR 20, OPPO BDP-83 BluRay player, Dish-HD, Infinity Beta 20's-C250-OWS1's, Dayton HSU10.
"Movie/Music room": Toshiba 65HM167 RPTV, Pioneer Elite 59txi, Elite DV59avi, Elite CD-59, Pioneer PD-51FD BR, Dish-DVR, Swan Diva...
Export to Wiki
#3
Rating: 0
If only numbers reflected what some manufacturers try to make it seem they reflect. Drawing the conclusions you are trying to from numbers is like looking at the gas mileage of two cars and wanting to determine which is safer in a crash.
They flutter behind you, your possible pasts.
Some bright-eyed and crazy, some frightened and lost.
Export to Wiki
#4
Rating: 0
Wattage is different than sound quality, which in itself is very subjective.
Export to Wiki
