Re: Connection Question
1). Both the dvd player and receiver have Digital to Analog converters in them. CD's and DVD's are digital but speakers are analog so the digital signal has to be converted to analog somewhere along the way. When you hook a cd/dvd player to the receiver with a digital (toslink or coax) the the receiver does the conversion. When hooked up with analog then the player does it. You don't really need both in most cases. Usually the receivers DAC's are as good or better then the players. Usually. I'd use digital in your case.
1a) Not sure exactly what you're asking but you only need to hook up the 6/8 channel analog outs on your Pioneer Elite dv-38 if you want to take advantage of it's dvd-audio capability. Otherwise, the digital connection is all you need. Even though the 38 is a very fine player I bet the DACs in the 07 are at least as good or better than the 38's.
2) No. Component is better so I'd use it over s-video.
3) The main benefit is you would only need to run one cable to your tv and the receiver becomes a switcher for your video components. I hook my stuff straight to the tv (my Harmony remote does everything anyway) but most run all video thru their receivers. Edit: Also, the 07 will convert all analog signals to 1080 and send them thru the HDMI output. But if you have a 1080 tv it will also do the same and even though one may do a better job than the other, usually the tv is pretty good at it.
"Everyday room": Mitsubishi 52631 RPTV, H/K 520, H/K dvd-5, H/K 8380, H/K CDR 20, OPPO BDP-83 BluRay player, Dish-HD, Infinity Beta 20's-C250-OWS1's, Dayton HSU10.
"Movie/Music room": Toshiba 65HM167 RPTV, Pioneer Elite 59txi, Elite DV59avi, Elite CD-59, Pioneer PD-51FD BR, Dish-DVR, Swan Diva...
Quote:
| Thanks for clearing everything up for me. |
I'm not so sure I did. Steven's response caused me to look at that JVC a little closer and, even though the manual was un-clear to me, it's quite possible that the S-VHS side will transmit thru the component output but it seems to me most S-VHS players only have composite and s-video. Also DVD/VHS decks require a separate connection for each side. So, to be honest, I'm not sure if you need both or not. Sorry.
Kevin, don't get too upset over the things people post on a forum like this. It's just not worth it. As far as I'm concerned you can ask whatever question you want. If someone wants to take a shot at answering it they should make sure he/she did what they could to get it right. I didn't take the time to download the manual to see if it's a question I
could answer so I'm the one who should have been criticized. And I don't mind. Never said I was perfect
