Michael TLV
- Michael Chen
- offline
Re: need help with screen
Greetings
Carada, Stewart and Dalite also have frames with velvet type material.
Don't compare gains between companies. It does not work that way. A Dalite 1.3 is not the same as a Carada 1.3 or a Stewart 1.3 ...
regards
Michael @ The Laser Video Experience
THX Video Systems Instructor
ISF Calibration Instructor
Lion A/V Consultants Network
Michael TLV
- Michael Chen
- offline
Greetings
A gray type screen if you have wanting blacks.
Do you have total light and room environment control? White walls and ceilings are not good for projected images. Nor are movie posters with reflective surfaces.
If you have a bat cave environment ... any 1.3 type material will be fine. Spend more on the screen since projectors tend to come and go more often than the screen.
go with black backing ... and avoid perforated screens.
regards
