Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Speakers and Subwoofers  ›  PIONEER VSX-1019AH-K RECEIVER, need speaker system
#1
Rating: 0
hey all. i need help choosing speaker system for my new pioneer receiver. could be 5.1 or 7.1 in range of about $500-$600 budget. thank you.
Export to Wiki
#2
Rating: 0
Re: PIONEER VSX-1019AH-K RECEIVER, need speaker system
For your budget, check this combo out:
Fluance SXHTB+ 5 Speaker Surround Sound Home Theater System
SVSound - Box Subwoofers
It's a bit above what you want to spend, but I think it would be worth it (especially the sub).
If you could stretch the budget just a little further, check out the $900 setup from SVS - SVSound - Complete Systems.
My Home Theater
Our DVD Collection
Dolby and DTS Plaques (downloads)
Export to Wiki
#3
Rating: 0
Very happy with our Energy Take Classics. Definitley in your price range if you haven't already purchased some.
Export to Wiki
#4
Rating: 0
Pioneer VSX-1019AH-K is easy to setup and it has a phenomenal ability to upscale and convert analog video signals to 1080p when transmitted through HDMI to your LCD HDTV. You also can plug in your iPhone and watch videos with the included cable without buying an expensive dock.
Export to Wiki
#5
Rating: 0
For that bidget, the Klipsch HD Theater 500 is right at $600 and are a great set of small speakers. The sub is a little weak though, but you could always save up for another one later on.
Export to Wiki
