Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Receivers/Separates/Amps  ›  Sony STR-DG1200 Help
#1
Rating: 0
I'm not getting anyware on finding info on the Sony STR-DG1200
I'm thinking about getting this model for the fact that it has a phono input and a optical out. But I heard it it does not pass audio over HDMI.
Anyone have this and care to comment please?
I\'ll Take 16mm 0ver dvd anyday
Export to Wiki
#2
Rating: 0
Re: Sony STR-DG1200 Help
It decodes the HD audio formats, so it does handle audio over HDMI.
It has 4 HDMI inputs, 5 optical inputs, and 3 Digital coax inputs, so you should be covered for anything you want to connect.
You mentioned it has an optical out (2 actually). Just curious..........what will you use the optical outputs for?
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
JBL PSW1200 (Sub)                        ...
Export to Wiki
#3
Rating: 0
Thanks Ed,
The one I look at only had one optical out. I want that for my cd recorder.
Do you have this model?
Export to Wiki
#4
Rating: 0
Quote:
Originally Posted by Roger Manning
Thanks Ed,
No. I got my info here: STR-DG1200 | Home Theater A/V Receiver (7.1 channel) | Sony | SonyStyle USA under the specifications tab...........
Export to Wiki
#5
Rating: 0
To bad they have the info wrong about the optical outputs. Make me wonder what else they got wrong.
I guess I will get one and return it if it does not pass HDMI audio as I have read in many reviews.
Export to Wiki
#6
Rating: 0
Sorry if it's wrong. May be a typo?
If you're sure it's wrong, send them an e-mail about it, so they can correct it.
Export to Wiki
#7
Rating: 0
Well I pick one up over the weekend for $449.00 I'll be hooing it up in the next couple days.
Let you know what I think.
Export to Wiki
