Re: denon "ext. in" volume level for each channel
Yes, that is normal. When using the "Ext. In", the player is doing the processing, not the receiver. That's why you need to set the distances and levels, in the player's setup menus too.
Most receivers don't do bass management while in Ext. In mode. I think most people sets the LFE level about 10 dB higher. Actually, all they usually do is control the master volume. There are a handful (or less) of receivers that will do bass management while in Ext In (multi-channel) made. Your owner's manual should tell you if your receiver does or not.
Samsung HL61A750 (LED DLP) Onkyo TX-SR805
Oppo BDP-83 Blu ray Polk Audio LSi9
Polk Audio LSiC Sony SS-MB100H
JBL PSW1200 (Sub) ...
