I just got a second pb10-nsd and it seems like there is a problem with my wiring. When the subs are in standby mode they buzz a little. Im not really sure if this was happening before with one or maybe I just didnt hear it. I have them plugged into two different outlets and both of them buzz. It does not affect the sound and is not audible until you put your ears up to the cone. It is also dramatically reduced when I unplug the sub cables but is still there but is barely audible.
Will this cause damage to my subs or is it just annoying for listeners?
I think I solved iti. It is the cable tv. I dont have a cable box so the cable just goes into the back of the tv. when I unplug it the buzz goes away to the point where you can just hear a faint buzz form the amp. I was reading about a cable tv isolator from jenson transformers that has solved some peoples problems. Do you think this is a good choice or will this just cause more problems down the line?
http://www.jensen-transformers.com/iso_vid.html
It is the VRD-1FF
It is the VRD-1FF
