Home Theater Forum  ›  Forums  ›  Home Theater  ›  Members Theaters and HT Projects  ›  Newbie needs help
Newbie needs help
#1
Rating: 0
Hi all. I am completely new to HT and this forum. I have lived in China for the past 16 years and don't go to the cinema here mainly casue I like to dsee movies ..not read them I do really miss the movie experience though and when the chance came via the purchase of my new home here I decided to retain one room for a home theatre.
The home decoration is finished now other than one room (HT) and I have begun researching the basics. With the wealth of information available on the web I am becoming overwhelmed and slightly afraid that I am going to miss something or make a mistake. The technology, terminoligy Wow I didn't realise it was all so complicated.
I am not in a hurry and have begun planning but I want to do it right - the first time. So I need input. My first hurdle is with accoustics and room dimensions. I cam across a spreadsheet on the web where you input your room dimensions and seat locations and it automatically calculates the accoustics. Everything else in the spreasdsheet is way over my head.
I cannot seem to input dimesions and seating positions to eliminate peaks and nulls. Am I being overly cautious here? It is only a small (16' X 11'X 9' high) room and I do not want to decrease the size too much for fear of losing space. All surfaces are currently concrete (everything in China is concrete) and I am planning a floating floor with insulated drywalls about 1" cavity to concrete on 4 sides and dry wall ceiling. Stage and floor to ceiling built in cabinet on front wall to house 50" flatscreen is also planned.
Am I heading in the right direction and how much should I reduce the size of the room for optimal accoustics?
Export to Wiki
#2
Rating: 0
Re: Newbie needs help
Hello down there on the bottom of the world LOL
Hey My first suggestion is to start with a AVR with this feature: "Audyssey MultEQ XT measures room acoustics and takes them into account when setting up crossovers, levels and delays so you get a well balanced sound" Example is the ONKYO TXSR706, which i just set one up in my brothers house and REALLY does it ALL. This feature measures all your room acoustics with an included microphone. It sets all the EQ and x-over for you!!
My next suggestion was to go for a matched set of speakers which will greatly improve the acoustical and tonal balance from the get go. (ie mix and match speakers sound horrible together) It assume youll be mounting on walls or floor standing since you have only 1" mounting depth. Also since your room is smallish, you may consider mounting BOSE CUBE arrays which take up very little space, and is readily available as a 5.1 speaker package.
Hope this gives you a boost and please email anytime w questions. GL
Export to Wiki
#3
Rating: 0
Thanks Glenn,
I checked out the Onkya on the web and can only find great reviews and comments so I gues that is a good starting point. Also I have always been a great fan of Bose so I'll probably go with the Acoustimass 16 Series 2.
I guess with the Onkya I simply build the room as large as possible. I a planning a floating floor which will end about 1/2'' form all walls. On top of this floor I plan to build the drywalls 3" frame 1/2" sheet both sides and glass fibre insulation between. Because the walls will line up with the edges of the floor they will also be away from the existing walls as will the ceiling. This was I am hopeing to create the room within the room concept.
My next dilema would be whether or not to proceed with the 52" flat screen TV or go with a larger screen and rear projector. Is the room large enough to warrant this or do you think it is too small?
Appreciate any and all advice.
Export to Wiki
#4
Rating: 0
I always recommend projectors. Flat screens are nice, until you realize that you could get twice the screen size for the same price or less. If you want the true theater experience, nothing beats a projector and a good screen. What is your budget?
Export to Wiki
