Re: Help on buying my first Home Theatre
If you can find this one over there, it will be a good one. It appears to have everything you'll need.
Onkyo HT-S9100THX - THX® Integrated System Plus? Certified 7.1-Channel Home Theater System | Model Information | Onkyo USA Home Theater Products
I guess to get the speakers tall, you could put them on stands.
And yes, these speakers should work with any receiver, but not all HTIB speakers will work with
any receiver.
Click on this link, then click on "See Rear View", and see the inputs:
HT-S9100THX Image Gallery | Onkyo USA Home Theater Products
4 HDMI inputs, 2 sets component inputs, and several analog inputs. It also has 7.1 multi-channel inputs. 2 Optical and 2 digital coax inputs tops it off.
Onkyo makes good stuff, and get good bang for the buck.
Samsung HL61A750 (LED DLP) Onkyo TX-SR805
Denon DVD-2200 Polk Audio LSi9
Polk Audio LSiC Sony SS-MB100H
JBL PSW1200 (Sub)
I know nothing about Australia. Sorry.
If you can't find anything good, locally, online may be your only option. Here in the US, I recently bought an Onkyo TX-SR805 receiver from Amazon.com, with free shipping. A lot of online sites will give free shipping when spending that much money.
As far as stands, it depends on what speakers you get, and how they attach to stands (on the bottom, screw to the back, or stands clamp to sides of speakers).
If you like the Onkyo HTIB I listed, you can contact Onkyo (through their site), and ask them what dealers are near you.
Good luck!
JBL PSW1200 (Sub)
Quote:
Originally Posted by disposedtrolley
I dont think i can find any stocklists in Australia for the Onkyo. Any other recommendation or could i just buy a HTiB and then get a good receiver?
You should just buy a good receiver and then get speakers (not a HTIB).
PS. you can't buy a Home Theatre. You can build a home theater or you can buy home theater equipment for your living room, but you can't buy a home theater.
\"the dream never dies, just the dreamer\"
