Home Theater Forum  ›  Forums  ›  Home Theater  ›  Basics  ›  Power center or Power distributor?
#1
Rating: 0
I am looking for a central power center type of unit that i can plug all my a/v components into so that i can switch one button and everything will be accessible. Is there such thing out there and what is it called?
I am familiar with surge protectors and power conditioners.
Is there something out there that look decent that will control my plugs?
thank you
Export to Wiki
#2
Rating: 0
Re: Power center or Power distributor?
Are all of your components remote controlled? If so, then use a standard surge protector (they are cheaper and work) and use a Harmony remote to control your equipment. No need to press a power button. When you change activities, the remote remembers to power equipment up and down as needed.
The few pieces of equipment that I have that don't have a remote are plugged into the switched power of my receiver or stay powered up 24x7.
-Robert
Export to Wiki
