Home Theater Forum  ›  Forums  ›  Home Theater  ›  Members Theaters and HT Projects  ›  Help with yamaha 863
Forum Nav
#1
Rating: 0
I have the 863 with klipsch surrounds and sub and iam very dissapointed with the sound. I need alot of tweaking. Also I tried to just use the hdmi from my samsung lcd to the input of the 863 just for audio and it was not working? any ideas
Reply to this Post Quote Multi-Quote Export to Wiki
#2
Rating: 0
Re: Help with yamaha 863
There's no way to say this without sound like a smarta$$, but it's the best first step you can take for yourself. Start by reading all of your manuals, especially the initial setup sections.
For instance, I would imagine your Samsung does NOT have an HDMI output. Most likely you just connected an input on the TV to an input on the 863. You'll need to connect your source components (cable/sat box, dvd, blu-ray, etc.) to the 863 to get sound...the 863's output will then then connect to the Samsung's input to pass the video along.
After you get that worked out, maybe you could better describe what else you're disappointed with.
-Brent
#3
Rating: 0
The 863 has YAPO so the 863 can calibrate audio settings for the speakers. I agree with Brent S. check the manuals and connections. During the self calibration you should have an on-screen display showing the speaker set-up and when the calibration starts each speaker will be highlighted on the screen.
