Re: Nine Inch Vinyl Tiles: Patch & Cover or Remove? Possible Asbestos
I've helped replace a few floors in my parents' house. In my experience, replacing only half the tiles and trying to fill in the gaps never quite evens out. If you use plywood or masonite with spacers to try even things out, it inevitably settles at an angle. If you use mortar, spackle or another kind of fill, it sinks further than you expect and it's again not quite even.
If you want to redo the floor, I'd either:
- Pull out the most damaged tiles (use a face mask just in case any asbestos dust kicks up) and lay down a new floor over the top with quarter-inch plywood. Once the new base floor is down, hire a professional to finish over the top. OR
- Use a face mask and pull up the existing titles yourself with a crowbar. There's nothing terribly tricky or technical involved, although it is physical so you'll probably feel it the next morning. Once you've gotten rid of the offending titles, call in a professional to finish on the original base.
If you lay down plywood on top, make sure the sheets you get aren't warped. Also, make sure your nails are long enough to reach the original base, and can piece through tile. Also, be sure to caulk the seams between the sheets so moisture doesn't build up in the cracks and cause mold build-up under the new floor.
The furnace shouldn't be a problem; more likely than not, it pre-dated the current floor, and the tiles were just cut around it. If this isn't the case, it might make more sense to put a new floor down over the old one than pull out the furnace to pull out any tiles it might be sitting on. Most likely, though, the job can be done without moving your furance.
