Re: panasonic bd55 & audio sync problem
Quote:
Originally Posted by Brad Newton
That is the reason that I went with the 55 over the 35. I really wasn't aiming to purchase a new surrond receiver at this time.
???? If you connected the 55 to your receiver via digital coax, you're not getting anything from the 55 that you couldn't get from the 35. Well, technically, the 35 only has an optical output, not both coax and optical like the 55.
To take advantage of the 55's onboard analog decoding, you have to connect the 5.1/7.1 analog outputs to the receiver. This opens up a different can of worms as the LFE channel may not be processed correctly via analog in your receiver.
If your receiver accepts HDMI audio, the 35 will decode TrueHD/DTS-HD to MPCM and output via HDMI. IOW, the 35 does decode TrueHD/DTS-HD just like the 55, but it doesn't have the analog output section.
Really don't know how to help you with the audio sync. Checked the 35/55/ manual, but couldn't find anything that looked like the 55 could be set to add some delay when using the analog outputs.
-Brent
