sup guys,
first of all this is gonna be my thread here on HTF, so excuse me if i ask you guys question that had been asked before. However, before I even had to write this thread I have been doing my research as well, but I can't really find the right solution for it. Here it goes...I'm looking for a best budget subwoofer. And so far I had nailed it down to 2 option, they are; Polk PSW10 or Dayton Sub-100 HT (Partsexpress.com). My living room spec; L 18' x W 12' x H 8', i'm gonna be using this subwoofer mainly for HT and 20% for music, my budget is <$150 (including S&H), and less boomy subwoofer the better. I hope a I covered all the info that you guys need to decide. Sooo...what would you choose or can you guys recommend me other subs..??
thanks ahead,
Ray
thanks ahead,
Ray
but I've listened to the MTX SW2 at circuit city several times and for only $180 it was pretty good! To me it wasn't boomy and like most other MTX products which are tuned for bass "punch" rather than ultimate low-bass extension (Cerwin-Vega is the same), this sub didn't rattle my colon but what it did have was quite enjoyable and definitely added to the movies and music I brought to listen to it.
