Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Receivers/Separates/Amps  ›  DTS Sound not working
#1
Rating: 0
I just got the digital coaxial cable for DTS and hooked it from my Sony blu-ray player (BDP-BX1) to my Yamaha HTR-5840 receiver, only there is no sound what so ever when i switch to the DTS format. Also, I'm pretty sure the 96/24 indicator is suppose to light up on the front panel display when the digital coaxial cable is plugged in, but that is not the case. I made sure to turn on the DTS in the blu-ray player set-up menu as well, but still no luck.
Does anyone have any suggestions? Any help would be greatly appreciated!
Export to Wiki
#2
Rating: 0
Re: DTS Sound not working
You set the player to output "Bitstream"?
You need to realize too that when a movie has a DTS soundtrack, you need to manually choose it in the movie's menus, under "Language" or "Audio Setup". Dolby Digital is the only digital soundtrack that's automatically detected, unless DTS is the only digital track.
The 96/24 indicator isn't going to come on unless the soundtrack is a 96/24 DTS soundtrack. Not all DTS is 96/24. I think it's mostly music tracks (cds or dvd-a, etc.) that uses 96/24 DTS.
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Denon DVD-2200                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
JBL PSW1200 (Sub)
Export to Wiki
#3
Rating: 0
Also the digital coax cable isn't "for DTS" it is for all digital audio formats - including Dolby Digital and CD formats. Finally you must assign the digital inputs (optical and coax) on your receiver to a particular video input. Unlike the analog inputs, they are not "paired" with a given video input by default. Check your receiver's manual for the procedure.
Joe
My Home Theater
My DVD Collection
My niece, "Miss Goofy Face"
Export to Wiki
#4
Rating: 0
I cant find an option in the set up menu for output: bitstream.
Here's what there is (Bold is what is have chosen. Is it right?):
Audio Output Priority:
-HDMI
-Coxial/Optical
-Stereo Analog
Audio (HDMI):
-Auto
-2ch PCM
BD Audio Setting:
-Mix
-Direct
Audio ATT:
-on
-off
Dolby Digital:
-Downmix PCM
-Dolby Digital
DTS:
-Downmix PCM
-DTS
48hz/96hz PCM:
-48hz/16bit
-96hz/24bit
Audio DRC:
-Auto
-Standard
-TV Mode
-Wide Range
Downmix:
-Dolby Surround
-Normal
Also, I did choose DTS in the movie's menu.
I did not assign the digital inputs on my receiver so that may be the answer.
Thanks for the help guys!
Export to Wiki
#5
Rating: 0
Did you figure this out yet? If not, try changing the BD Audio Setting to Direct.
Larry
Export to Wiki
