I have decided to finally repaint my living room/media room.(PJ and tv)
It is off white and even though I get a TON of sunlight(if wanted) it makes me so depressed and it kills my PJ.
So, I'm lloking for advice on painting.
It is a 14.5' x 14' room, that extends into a kitchen that is 14' x 11'.
The far left wall extends from the front of the house to the rear.(from front of living room to rear of kitchen.
The opposite right wall ends short of the 14' length, which then is a hallway.
The ceiling is vaultd and goes from 9'h at the front to ~14'h at peak and then back to 9' at back of house and kitchen.
I was thinking of a chocolatre brown or something along those lines on at least the long left wall that runs the full house as an accent wall(*this is the wall my PJ screen is on)
Tryting to paint all four walls though, maybe a light pale blue shade on the ther walls?
*I definitely do not want four dark walls.
The ceiling above that screen wall goes like this \, but at a less severe angle.
Thanks for any and all help!
