Re: Surround Sound for Cable TV
You have the optical cable connected – but are not getting sound from all of the speakers.
So, a signal is getting from your box to your receiver – so you now need to debug the rest of the issues.
Going into debug mode – just follow the signal until you uncover and fix the problem – here is how I would do it.
– You have a DVR with some kind of setup, a receiver with some kind of setup, and speakers that you have connected to it.
To ensure that the speakers are indeed connected correctly (no loose wires) – the receiver should have some sort of test tone generator in it. This is used to balance all of the channels (there are separate threads on how to do that) – Go ahead and balance the speaker levels of your system – it could be that the speakers you are not hearing any sound from are just set to a very low level – and setting the sound levels is a good idea anyway.
Make sure that all of your speakers are connected correctly – ensure the sound is coming from the correct speaker in your setup – the sound generator will cycle through all of the channels (left front, center, right front, right rear, left rear, and sub)
Now – after that test – you can rule out the receiver to speaker connections.
Next – make sure the receiver itself is setup to output all of these channels – if it is not setup correctly, the above test might also point this out. This test signal will cycle through the speakers that the receiver is setup to output – so if it thinks there are no rear channels connected, it won’t send a signal there.
Now – if this test also passes – then you need to look at your cable box – there may be a setting to output DD over the optical cable for a 5.1 channel system. Since you are getting some sound – this might be OK...
One more thing it could be – even with all of the connections and setup working correctly – most sources from the cable service will not be using the rear channels very much. You may just be watching a source where there isn’t much surround info.
