Home Theater Forum  ›  Forums  ›  Hi-Definition  ›  HT Hardware - High Definition  ›  PS3 audio to a Bose 321
#1
Rating: 0
I have a ps3/80 connected via optical cable to a bose 321 any advice on audio settings to get the best sound possible. ex. bitstream vs PCM etc.
Export to Wiki
#2
Rating: 0
Re: PS3 audio to a Bose 321
Quote:
Since you´re using optical, you only get the "core" from DTS-HD MA (core is "DTS - 1.5 Mbps") and Dolby TrueHD (core is "Dolby Digital - 640kbps", I believe?). So use bitstream.
Rewind - DVDcompare/Site Administrator
*US PS3 (1080p) - Xbox 360 Elite (HDMI) - Nintendo Wii (Euro) - Sony PSP-2000 - Nintendo DSi
*HD DVD Toshiba XE1 (1080p) - Sony Bravia KDL-40W2000 (1080p) - Yamaha RX-V1800 (HDMI 1.3)
Export to Wiki
#3
Rating: 0
Thanx, i appreciate the reply. So when the ps3 says choosing bitstream may leave out some audio, i should just ignore that in my situation. Also when i transfer cd's to my ps3 what format should i use AAC, MP3
Export to Wiki
#4
Rating: 0
It is up to you obviously, but I would use a format that would allow you to use the music with a number of devices.
Export to Wiki
