JohnRice
- John Rice
- offline
Re: URGENT NEED HELP PLEASE
Every thread you have ever started has had the title in all caps. You don't need to do that, it is in poor taste, and, as I recall, it is also against forum rules.
In addition to that, you rarely return to the threads you start.
They flutter behind you, your possible pasts.
Some bright-eyed and crazy, some frightened and lost.
Is this really urgent?
--ignore the man behind the curtain
Quote:
Nope, not at all.
Quote:
| Thats your opinion. Instead of putting me down look at yourself. |
He didn't put you down, he offered a bit of constructive criticism that will (if heeded) help you fit in better with this community. So, would this be a bad time to point out that "URGENT NEED HELP PLEASE" is a poor thread title even without the ALL CAPS issue? (Or the lack of urgency issue?)
Most threads in the hardware forums are request for help of one kind or another, and everybody thinks their request is urgent. So the title bascially conveys zero information beyond, "I'm a thread in a hardware section."
Personally I tend to skip the "generic" threads, because there are only so many hours in the day, and I know more about some aspects of home theater than I do about others. I tend to hone in on the threads where I think I can help and ignore the others unless I think I can learn something. I know lots of other members who do the same.
"Help with Subwoofer" would have been a better title. "Help with Riesen Subwoofer" would have been even better, as that would have attracted the immediate attentions of folks with experience with that brand. It is always best to use the most specific title (of a reasonable length) possible. "Help with Samsung XYZ25 LCD TV" is better than "Help with TV", "Help with Samsung" or "Help with Samsung XYZ25". (Or "Help with XYZ25" which could be anything from a clock radio to a front projection system.
Joe
JohnRice
- John Rice
- offline
Quote:
Originally Posted by Lew Crippen
who is very able to deliver a withering broadside should he so choose.
I resemble that remark. An unfortunate fact, though it has come in handy a couple times. Mostly I've regretted it though.
