Home Theater Forum  ›  Forums  ›  Hi-Definition  ›  HT Software - High Definition  ›  Why do some BD take longer to load than others?
#1
Rating: 0
I noticed that depending on which studio the disc is from the longer or shorter it takes for the disc to load.
Why is this? Does it have to do with the amount of content stored on the disc?
Fox and Disney titles take the longest i've noticed but with Disney you get animated loading icons like the spinning Piston Cup on the Cars BD.
I'm still learning all the in's and out's of BD and am curious about this.
Thanks.
"You have no idea how far i'm willing to go to acquire your cooperation." - Jack Bauer
Export to Wiki
#2
Rating: 0
Re: Why do some BD take longer to load than others?
Depends on if the disc uses BD-Java encoding, and if it does, just how fancy that encoding is. Disney and Fox like the bells and whistles of BD-Java menus, hence the longer load times. Warner, on the other hand, likes things streamlined, and only uses BD-Java encoding when they have a special feature that uses it (Picture-in-Picture commentary, for example).
My DVD/BD Collection
Criterion DVD/BDs Owned: 55, Total DVDs Owned: 527, Blu-ray Discs Owned: 223
Export to Wiki
#3
Rating: 0
No problems with loading if you are using PS3 or HTPC, but on stand alone players aside from frequent FW updates, yikes!
Check out Universal Blu-ray discs, no fuss no muss, quick to the point
Export to Wiki
#4
Rating: 0
Thanks, that makes sense, not that I was complaining about it because I have no problem with the load times, I was just curious that's all.
I am wondering, though, why do they load quicker on a PS3 than they do on a stand alone player?
Export to Wiki
#5
Rating: 0
d/p
Export to Wiki
#6
Rating: 0
Because the PS3 is massively more powerful than any stand alone player.
Export to Wiki
