Re: Ok, newb question about a subwoofer
I'd get a cheap sub just to protect your speakers. You can get a Sony, Yamaha, etc. for around $100 on ebay. Or maybe something used. If you decide not to get a sub until you can afford that SVS, I'd set the crossover on the receiver to at least 60 just as a precaution. That's what I'd do, anyway. Nothing worse than blowing a speaker while saving for a sub.
"Everyday room": Mitsubishi 52631 RPTV, H/K 520, H/K dvd-5, H/K 8380, H/K CDR 20, OPPO BDP-83 BluRay player, Dish-HD, Infinity Beta 20's-C250-OWS1's, Dayton HSU10.
"Movie/Music room": Toshiba 65HM167 RPTV, Pioneer Elite 59txi, Elite DV59avi, Elite CD-59, Pioneer PD-51FD BR, Dish-DVR, Swan Diva...
McLoki
- Michael Hand
- offline
Personally I would just due without until you can get the sub you want. The only deviation from that would be if a great deal comes along used and you are pretty confident you can flip the intermediary sub for close to the same price you paid for it.
Mains............Polk LSi15 (Cherry)
Center...........Polk LSiC
Surrounds......Polk LSi7 (Gloss Black - Wood sides removed)
Subwoofers....SVS 25-31 CS+ and PC+ (both 20hz tune)
Pre\Pro..........NAD T163 - Modded with LM4562 opamps Amplifier.........Cinepro 3k6 (6-channel, 500wpc@4ohms)...
The answer depends upon many variables. A "cheap crappy sub" is subjective to room, listening levels, performance expectations, etc.
I would say that including a sub into your system will help, affording a quality sub is, again subjective.
I included a very inexpensive sub into my system about 6-7 years ago and I was well pleased. Then I started reading this forum and others only to find out that there were much better sounding units out there and I really didn't know what I was missing. Sure I went to theaters and enjoyed the emersion into what I though was quality sound.
I have since upgraded( SVS PB-Ultra 13) but if I listened to ALL the hype I'd still be shopping for the "perfect" sub. This animal doesn't exist.
I'd say incorporate what you can afford with due diligence to a price range that members here can help you with. Outline your listening habits and volume levels desired. Make sure to invest in calibration equipment. It is not expensive.
I have several friends that purchased subs in the couple hundred dollar range and they were extremely disappointed until they calibrated and they are now satisfied. Yes, they know there is better and have heard better but they are at least getting LFE involved into their soundtracks.
I am positive there are better sounding systems than what I have but it is what I can afford and I get pleasure from it. BTW, there is ALWAYS something "better" = more expensive.
Have fun!!
.....this is truly an illness
JohnRice
- John Rice
- offline
Well Robert, your endless touting of DIY subbing may be wearing me down. In the coming months (probably more like year) I am hoping to do some experimenting. I can do a lot of the fashioning myself, but I also have some others available for some the of more precise woodwork.
Is there a software app for Mac, or am I stuck using windoze to do the calculations and basic design. At first I am probably thinking sonosub with external amps, just so I can scrap one effort with minimal lost $$.
I was looking at TC Sounds, and holy crap those drivers get stinking expensive.
They flutter behind you, your possible pasts.
Some bright-eyed and crazy, some frightened and lost.
JohnRice
- John Rice
- offline
Thanks for the info Robert. I have an Intel mac at work, so I could always use that for the design app. Just as general suggestions, what drivers are recommended to create a sub in the SVS PB12/Plus-2 to PB Ultra 13 range? I'm just wondering about cost.
As far as sonotubes, I know a lot of people in construction, so I can probably score some scrap tube if I try. Not sure if it will be difficult to get it undamaged. I would think there is someone I can go to and ask "can you knock 3 ft off one of those?"
JohnRice
- John Rice
- offline
Robert, yeah I'll start a thread in the DIY section. I'm just being lazy.
Sorry about the hijack Wil.
