Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Hi-Def Source Hardware (Players, STB and Cable Boxes, Antennas etc)  ›  Can I use BD50 internal audio decoders but output through Coax?
#1
Rating: 0
Looking into the BD30 or the BD50. I don't have an HDMI compatible receiver, but it is 7.1 capable. Wondering if I use the internal decoders (TrueHD, DTS HD), can I then send the 7.1 signal into my Denon AVR 3803 via Coax or optical and still get the 7.1?
Export to Wiki
#2
Rating: 0
Re: Can I use BD50 internal audio decoders but output through Coax?
Quote:
You won't get either TrueHD or DTS HD that way. You'll get a core signal (and I'm not sure it'll be 7.1). However, if you hook up the analogue output of the BD50 (not available on the BD30) you will get TrueHD and/or DTS HD. The catch is the BD50 does not have 7.1 but rather 5.1 analogue outputs. The upcoming Sony S550 is supposed to have 7.1 analogue output.
I think some Pioneer and Denons have 7.1 analogue outputs, but they are quite a bit more money and are not all Profile 2.0
Never try to teach a pig to sing. It wastes time, and it annoys the pig.
Export to Wiki
#3
Rating: 0
No. Coax and optical are restricted to standard DD and DTS lossy codecs. The only way to get TrueHD or DTS HD MA is through an HDMI connection or through multi-channel analog outs.
It looks like the BD50 has 5.1 analog outs, so TrueHD and DTS HD MA over the analog outs is restricted to 5.1.
Your spurs.....
There are two kinds of spurs, my friend!
Those that come in by the door...
Those that come in by the window.
Export to Wiki
#4
Rating: 0
Thanks, guys. makes sense. What about regular old DD or DTS 6.1 and 5.1? Can I get the same audio outputs on these players that I enjoy on my current standard DVD player including DD EX and DTS ES?
Export to Wiki
#5
Rating: 0
If it is something that ordinary DVD can offer, the BD50 should also offer it in the audio department (as should any Blu-ray player, for that matter). There may be individual exceptions, though, so it is worth checking first.
Export to Wiki
#6
Rating: 0
Is there a player that offers a picture on par with the Panny, but also offers the 7.1 analog outs?
Export to Wiki
#7
Rating: 0
The Sony S550 is probably what you will want. The Denon and Marantz and Pioneer are quite a chunk of change, enough to almost justify buying a receiver with good video processing on top of a S550. I doubt you'll be able to tell the difference in picture quality of blu-ray for the S550 vs BD50. DVD upconversion? yeah maybe...
Export to Wiki
#8
Rating: 0
Thanks. From what I've read, the Panny suffers a bit in the up conversion department anyway. How's the Sony rated? Anyone have this machine yet?
Hal
Export to Wiki
#9
Rating: 0
It's not released yet but should perform well.
Export to Wiki
#10
Rating: 0
This is one thing that really confused me at first when both HD-DVD and Blu-ray came to market.
Both Dolby TrueHD and DTS-HD are backwards compatible, in that they contain an embedded "legacy" core encoded soundtrack. The nice thing about this is that, on most discs, the legacy core is at a higher bitrate than DVD. For example, most Dolby TrueHD soundtracks have a Dolby Digital core encoded at 640 kbps, versus the max 448 kbps on DVD, and most DTS-MA soundtracks have a DTS core encoded at 1.5 Mbps.
All you need to do when watching a Blu-ray disc is choose the Dolby TrueHD or DTS-MA soundtrack from the disc's setup menu, and your receiver should recognize the stream as either Dolby or DTS. You may need to select optical or coax digital audio output on your player, though.
No matter how much the movie insists that there's tension, I must respectfully disagree with it. - Crow T. Robot on "The Blood Waters of Dr. Z"
Export to Wiki
#11
Rating: 0
Wow. That's great. Didn't know. Does it maintain the 7.1 mix or 6.1 or does it make them all 5.1? I ask only because my receiver is 7.1 but has no HDMI input. Been considering the new Sony (due this fall) with 7.1 analog outs. Any reason not to do this?
Export to Wiki
#12
Rating: 0
The "core" track is only 5.1. If at all possible get the Sony with 7.1 pre-outs, you'll be glad you did
Export to Wiki
#13
Rating: 0
Read this on another thread:
Quote:
I would avoid investing expensive sums of money in Blu Ray players with 7.1 Analogue Outputs as there is some evidence circulating the web to suggest that the analogue output stages of a significant number of players supply a decoded version of the 'lossy' soundtracks of Blu Ray rather than the lossless formats.
Anyone know anything about this?
Export to Wiki
#14
Rating: 0
If this is true, it's not in the documentation of the players and it's not something I've heard of. Unless he is talking about most players not being able to internally decode DTS-MA, however the Denon, Marantz, and Sony 550 can.
Export to Wiki
