Well, I've been toying with the idea of jumping into vinyl for a while now. I've been quite dissatisfied with the whole compact disc thing (puny artwork, brittle "digital" sound for older analog masters, which is most of what I listen to, stuff I want to hear that's only available on vinyl, etc). I remember hearing a friend's turntable and was blown away by the warmth and musicality of it and immediately knew what i was missing...
But it seems like a dizzying and daunting field. Basically, I just want a good, solid player (Technics seems to be the best and most durable for the $500 range). BUT I have some questions:
-Do I need a pre-amp (see below for my current speaker/amp setup)? I've heard some turntables have them built in, but I dunno...
-What stylus is a good match for a Technics? I'm looking at the "classic" 1200 MK2 model. I'm on a budget here: I don't want to spend more than $100 for a stylus...
-Any other recommendations for a good mid-range turntable? That is, no more than $500
**MY CURRENT SETUP: I have a 5.1 home theater setup (JBL Northridge E series speakers and a 10" SVS sub) and a 6.1 Denon receiver (AVR 1705). I know this setup is optimized for films, but I would assume the speakers would get the job done for vinyl too right? But most importantly, with this setup, would I need a separate pre-amp? For what it's worth, I don't see a "phono" jack in the Denon manual, which is usually what's used to connect a turntable, right?
THANKS for any help on this!
