Greetings,
Hoping the expertise of the community will help me make sure my set up is correct. Thanks in advance!
Setup:
Definitive technology: 7004 supertowers front, clr 2300 center, and 4 bp1.2x bipolar surrounds.
BUT no sub woofer.
Denon 3808 amp.
Room size: 15 X 25
Now one of the reasons i got the fronts and the center was because they have self-amplified subs built in, which i wanted to make up for not having a dedicated sub.
Question 1: am i correct in understanding that by setting up my system through the denon with no sub that the front and centers (large) will still play bass sounds, but any bass that would come through the surrounds would just be lost? That the fronts / center would not play bass sounds from the surrounds. (i do realize that with most movies that would rarely happen but...)
Question 2: The 7004 super towers have a LFE input in addition to the standard speaker connection . Am i then able to also connect them as if they were subs through the denon? Does that mean they would then play bass sounds for surrounds?
Question 3: if I can connect the super towers as subs, is it not straightforward? in other words, i have two LFE inputs (one for each front) but only one LFE output on the denon. Can i just get a splitter to run to both fronts, or will that cause problems?
Thanks again!
Setup:
BUT no sub woofer.
Denon 3808 amp.
Room size: 15 X 25
Thanks again!
