So my wife parks in a parking building for work and has been bugging me about a locking gas cap. Today, she noticed the cap was very loose and she thought she might be lower on gas than she should be.
I'm thinking it's not likely. After all the cap is behind a door that needs to be opened from the interior of the car. If it was pried open, it would show. Still she wants one, so I'd better get one.
Am I better off going to the dealer (2003 Honda CRV) or after market, like Napa? Who's going to have the best product?
Johnny
www.teamfurr.org
Another cat? Perhaps. For love there is also a season; its seeds must be resown. But a family cat is not replaceable like a wornout coat or a set of tires. Each new kitten becomes its own cat, and none is repeated. I am four cats old, measuring out my life in friends that...
JohnRice
- John Rice
- offline
Re: Need a Locking Gas Cap?
Product will probably be exactly the same, but half the price at Napa. Never buy from the dealer.
They flutter behind you, your possible pasts.
Some bright-eyed and crazy, some frightened and lost.
Radioman970
- James Perry
- offline
interesting question. That would sure ease my mind. I've been thinking about getting one as well. The level on my gas gauge changes often...up and down. It's weird. I'm mostly on level ground. I think somebody is putting gas in mine heh!
Real Name: Arthur Belling of "St. Looney Up-The-Cream-Bun-and-Jam"
BEAR: 1992?-2007.
GOLDIE: 1997-2008.
Still mourning my girls.
Quote:
Originally Posted by DaveF
Don't cars from the past 20 years have grills in the gas tank inlet to block a siphon hose? Wouldn't that have to be broken first on your wife's car before gas could be siphoned? Can you check for that?
I've heard that too, that somehow newer vehicles cannot be siphoned.
I guess that's why some desperate people are just punching holes in the gas tank under the vehicle and draining the gas that way.
I also agree that if you have a gas cap door that cannot be opened except from inside the cabin, and the door has not been pried open, your wife may just be paranoid.
Uncle Joe: I'll never marry you, Selma Plout! You may as well take off that wedding dress and put it back in your Hopeless Chest!
--Petticoat Junction--
#1 cause of that pesky "check engine" light coming on is missing or loose gas cap, #2 is gas cap that doesn't hold both pressure and vacuum, i.e. wrong aftermarket locking caps. If you must buy one be very careful to make sure it will work with your specific make and model car.
Steve S.
I prefer not to push the subwoofers until they\'re properly run in.
Or get an OBD-II scanner and reset the code every few weeks. IMPORTANT don't reset right before a smog check and make sure the "monitor" programs have all run through. Putting the OEM cap back the week before the test would be a good idea too.
Miatas are very prone to throw a CEL even with a factory gas cap and even if you more-or-less tighten it up after filling.
Feline videophiles Susie and Dukie.
Buzz Foster
- Steve
- offline
My Tacoma has a locking door over the cap. The Vulcan has a locking cap.
Look up! Scream in terror! Get smooshed! Fear me, for I am PARTYZILLA!
facebook.com/getthebuzz facebook.com/partyzilla
