I have purchased a new SVS PB-10 Subwoofer for my home theater system.
I am currently having some problems getting the subwoofer to sound the way one would expect. Booming bass etc.
My current setup is:
Receiver: Pioneer VSX-1016
Front: Cerwin Vega VS-120
Center: Klipsch SC .5
Rear: PSB Alpha A/V
My room is 10.5 feet wide by 21 long
Carpet and underlay ontop of concrete.
I have the sub beside my TV facing forward with the mains in the corners of the room.
My sofa is about 15 feet away from the TV in the center of the room.
The problem I am having is that I can feel like bass durring movies etc but it does not have that booming sound it to.
It is more booming if you were to stand up then if you are sitting on the sofa.
I have gone through the MACC setup on the receiver as well as going through the manual and manually changing settings. All of this with no change.
I have tried moving the sub around from the corner of the room and along the inner wall of the house (it is a semi). All of this and I am still unable to get it to boom.
Can someone give some assistance on making this sound the way it should?
Or is it possible my room is just not theatre friendly?
Any help would be great.
Diego
Rear: PSB Alpha A/V
Diego
). Could be your sub could use some equalizing - most do.
