Re: Could Lack of "1080p/24" Be The Problem?
Thank you very much for your insights, Jari; let me see if I can address these issues individually that you have documented below, and then I'll get to the other member who posted after you...
IMO, not really, 24fps is not "mind blowing". Most Blu-ray/HD DVD-titles (at least film-based!) are 24fps on the disc, so if you have BOTH the player and TV/projector that supports also 24fps, you´ll get less of that minor "judder" that you can see (or should I say: You MIGHT see) in some of the films/scenes/shots, mainly where the camera is panning or tilting, I guess.
Thank you; suppose this answered the main question of my thread...I will not worry about 1080p/24 right now then...
Read this link for more info:
High-Def FAQ: What's the Big Deal About 1080p24? | High-Def Digest
One important quote: "1080p24 output is only beneficial to content originally photographed at 24 frames per second".
I will read that just as soon as I get a second...thank you...
Oh boy.
Most films are shot in "film", and e.g. "grain" is natural part of the film stock. Some have more and some have less, but grain won´t go anywhere with e.g. Blu-ray-titles (it´ll GO away with digital animation-titles like "Cars" and "Ratatouille" - they are not "shot in film"). I´m afraid your expectations are just too high - and also unrealistic in some ways.
Well, let me start with saying that I am totally aware of the fact that film will have grain inherent in it -- I understand that...some titles I own or have rented, though, seem to have an almost "DVD quality-like" noise or grain to them, and it seems a bit dissapointing as sometimes it seems like it's "robbing" the Blu ray of its impact...now, let me explain further below:
It´s also hard to say for sure, that is your TV 100% correctly calibrated, etc etc. There are zillion things that could matter.
...and THAT'S what I'm trying to ascertain...where the issue is coming from...indeed, I have been told that 100 percent calibration will eliminate any "worries" about the quality of these discs, but to be truthful, I simply can't afford an ISF tech right now and I'm not about to play Russian Roulette in the TV's service menu...so, I calibrated off a disc with instructions and it seems to be the best I can get this screen right now -- BUT...I AM using Sony's "Standard" picture mode, not Custom, which opens up other selections for Detail Enhancer, Black Corrector, Live Color, etc...yet when I have calibrated in Custom mode, the results of these films played back on my screen didn't look all that different from Standard mode, except it made the screen a bit dimmer -- but could this really be affecting the "noise" I'm seeing onscreen?
It´s not "lack of 24fps". Film has grain and some other issues. e.g. "300" will be very grainy (originally), no matter how well the set is calibrated, no matter how good your TV is etc.
So again, about those expectations...
No, I TOTALLY understand that -- some films are absolutely intended to be grainy, and I expect and respect that...it's just that the discs on my Panasonic player coming off my Sony HDTV don't look...all that...well..."high def"...
I would keep them definitely "off". You don´t need any "phony" picture processing with Blu-ray/HD DVD-films. 1080p will keep the quality high (of course, not always - there are some mediocre releases/transfers).
Okay; this is interesting input...someone on another site also told me to keep the Blu ray Noise Reduction OFF, but to keep the standard DVD NR ON -- and with standard DVD, you can DEFINITELY see a difference in how the circuit eliminates some of the noise...but I thought it was working, too, on Blu rays...would you DEFINITELY recommend leaving noise reduction OFF when watching high def discs? And my player is set to AUTO HDMI resolution, which "selects" 1080p playback based on my screen's resolution...
They *might* help with SD DVD (IMO, I would keep them "off" with SD DVD also) and some TV-signals (with those I could keep them "on" for some cases).
Well, I'm talking about the noise reduction on my BLU RAY PLAYER, not the TV (which has its own noise reduction, too) and when you watch standard DVD or Blu ray, the menu pops up on the onscreen menu of the player to select noise reduction on or off for the individual formats...and I said, this seems to work on standard DVDs...I can't really see a difference in Blu ray, but if you think it's best to keep this OFF for high definition, I will.
Now that we're on the topic, would you recommend leaving my Sony TV's NOISE REDUCTION off, low, medium or high? I have it OFF right now for the Blu ray HDMI port, but should it make a difference?
Quote:
Originally Posted by Brian Borst
By the way, 1080p/24 and the 'noise' you're seeing (I take it it is actual grain you're actually supposed to see) aren't related. It has to do with bitrate, not with the quality of the BD you're playing.
Thank you, Brian; this has cleared a lot up for me.
