Since school is about to let out, I'm going to replace it with a little DIY subwoofer project. Not going to be anything big, probably just a little 10" sub to decide if I like to build DIY subwoofers. My budget isn't too big, just ~$100-$200, just in case I wire it up wrong or something and send a driver to its grave, it wont be the end of the world.
What I was thinking was a Dayton 10" DVC Subwoofer with a Dayton 100W Subwoofer Amplifier($117 combo).
Another combination I was looking at was a 10" Shielded Paper Cone Subwoofer with a AudioSource AMP100 2-Ch Source Switching Power Amplifier ($116 combo)but seeing as the price of that driver is only $16, I'm not sure if it would be as good of quality as the Dayton.
As for the enclosure it will be going into, I had mixed thoughts about either ported or sealed. Sealed would be easier to build but would be untunable. Ported would be harder to build with would probably sound better due to the tune ability. I'll probably end up going with a 12"H x 12"W x 15"D (internal) sealed enclosure, which should be a decent enough size.
The receiver I'll be using it with would be my computer, which I have a cable to connect from the computer to the subwoofer. The speakers I will be pairing it with is the Logitech X-530 (a friend gave them to me for free a few weeks ago.) which will only be used until next summer when I begin finding a receiver and speakers to replace them.
Thanks in advance.
Thanks in advance.
