There was an electrical storm the other day, and I guess I took a hit because my hot water heater was knocked offline and the electronics were all fried. I got a new one, and now I have a strange problem.
I've got a single knob control for hot and cold water, and I've traditionally been able to shower with the indicator pointing straight up, maybe moving it to the left a little if the water started to run cold. Now, I get that same performance in the tub's water spout, but when I engage the shower (a pull-up device), the straight up position is cold water. I have to turn the knob all the way to the left, and the best I'm able to get is tepid. But, as I said, if I turn off the shower and just use the spigot, all the way to the left is scalding hot. And, I get the full range between middle and full left.
What could be the cause of this? I mean, there's not much to a shower--the rod just diverts the water from the spigot to the shower head. How can there be a temperature difference? The only thing I can think of is that the cold water valve is stuck open, but why does it only affect the shower?
