Re: Problem with my MBP, or feature?
It seems like the larger problem is my battery... Three times now my MBP has shut down with about 30% left on the battery indicator. If I try to turn it back on, it just shuts off again right away. I tried reseting the power management chip thing, but either I did it wrong or it just didn't work. I went into system profiler to see my batteries properties, and get this:
Battery Information:
Model Information:
Serial Number:Sony-ASMB012-36b6-c3bd
Manufacturer:Sony
Device name:ASMB012
Pack Lot Code:0003
PCB Lot Code:0000
Firmware Version:102a
Hardware Revision:0500
Cell Revision:0303
Charge Information:
Charge remaining (mAh):2919
Fully charged:No
Charging:No
Full charge capacity (mAh):3279
Health Information:
Cycle count:22
Battery health:Fair
Battery Installed:Yes
Amperage (mA):-1417
Voltage (mV):11844
Based of reading the support forums at Apple.com, I've learned a few things. One, that this isn't an uncommon problem, and two, a new battery should have a capacity of around 5500 mAh, not the just over 3000 I'm getting. I'm hoping this is just a battery problem. I'm doing the battery calibration procedure right now to see if that works, but I'm betting not. If not, I'll just call AppleCare tomorrow and see if they can send me a new battery.
I'm thinking it's probably isolated to the battery because I've had no problems while plugged in, other than the sleep thing. I found that if I just close the lid again, wait a second, then reopen it, it will wake up.
This is aggravating... I love my new Mac but I've also never had a new PC with issues like this
