First, no, I'm not trying to pirate something =p
All I wanna do is grab a 15 second sound clip and save it to an MP3 and also get a single full size screenshot off a DVD.
What's the fastest, easiest and cleanest way to do this on OSX, preferably for free?
Blog: Navesink.net - My Flickr Stream is here - Click here to Email me - Updates at Twitter & FriendFeed
Information Technology Blog: Infotechbuzz - Save The Alamo - Join the HTF Flickr Pool or discuss the pool here
"Buncha Savages in this town"
JohnRice
- John Rice
- online
Re: Sound clips from DVD
I have grabbed sound clips by basically routing the audio output back to the input and capturing with CDSpindoctor, which is part of Toast. I believe there is a shareware app which can do it easier, but I forget the name, and you have to pay to do it.
Screen captures are a bit stickier. I think you can play the DVD with
VLC, pause, and do a regular screen capture, but you get a somewhat low quality image. This does not work with DVDPlayer. There is another, higher quality method I know of, because I like getting movie stills, but it involves software which can't be discussed on HTF, because it is capable of other bad things in addition to the screen captures.
They flutter behind you, your possible pasts.
Some bright-eyed and crazy, some frightened and lost.
OK John, Thanks for the info! I guess I'm gonna have to do this on the PC cause it seems a LOT simpler to do there with free software...
Cinematize is probably the best (without using final cut). It's pretty inexpensive and easy to use.
I've been thinking of getting Power DVD Ultra for the PC anyway, maybe that's the way to go. Still looking into Cinematize tho!
That looks perfect thanks!
