Home Theater Forum  ›  Forums  ›  Home Theater Hardware  ›  Audio/Video Sources  ›  hd audio
hd audio
#1
Rating: 0
I have dish network with hd channels, and on all the hd channels the volume is lower. Is this a common problem or something that can be fixed?
Export to Wiki
#2
Rating: 0
Re: hd audio
It's common and there is really no way to fix it except complaining to the provider. In reality, since DD has a higher dynamic range there should be a difference in the output, with DD being lower. But I don't think this is the case with broadcast, because my HD volume output on cable is all over the place, changing even from commercial to commercial, never mind channel to channel.
Export to Wiki
#3
Rating: 0
Re: hd audio
Ok just making sure i didn't have a problem. thanks for the response.
Export to Wiki
#4
Rating: 0
Re: hd audio
There's no such thing as HD audio.
Export to Wiki
#5
Rating: 0
Re: hd audio
Quote:
How true!
On the BluRay discs the difference will be that the audio is uncompressed which will give it greater dynamic range.
As for variance in volume, that's pretty standard for all forms of television, and commercials are ALWAYS louder than the show you are watching.
kitchen range hoods
Export to Wiki
#6
Rating: 0
Re: hd audio
Just like Dolby 2.0 is louder than 5.1 I alomst blew my ears off!
Export to Wiki
#7
Rating: 0
Re: hd audio
Well, there is! HD (digital) radio has been around for a while.
--ignore the man behind the curtain
Export to Wiki
#8
Rating: 0
Re: hd audio
Quote:
Which brings the question: Like AM Stereo, if something has been around but is never heard by anyone, does it really exist at all?
Export to Wiki
#9
Rating: 0
Re: hd audio
Now! on a stereo near you: trees falling in the forest with no microphone around!
Export to Wiki
#10
Rating: 0
Re: hd audio
Plus, it only costs $200 to not hear it!!
Export to Wiki
#11
Rating: 0
Re: hd audio
ha ha ha ha ha ha....reminds of the (mime) Marcel Marceau album. No, he really did put out an album. Lots of quiet, scuffling sounds, then audience laughter. Priceless.
Export to Wiki
