Well folks, hello to the newest home theater addict on the block. Only problem is, I'm broke! So broke I could only afford an 805 and so far only have my fronts and center channel. (going peice by peice). That said, I'm having a bit of trouble trying to figure how to tie my television into my setup considering I have no cable box. Only the basic old school screw into the back of your television type cable.
Trial, error, and alot of headaches until 3am managed to get my wii, xbox360, and ps3 all hooked up with audio but I'm at a loss at what to do with the television and how to hook it up. Currently I have the audio working via optical however I would like to be able to hook the tv up to the receiver so I can do all the switching from the receiver and put down the multiple remotes deal. That said, my television is a VIZIO VW42L HDTV10A.
Assuming it is possible, I would like to bring up one more problem that I could use help with. Via the hidden menu you are able to set upscaling and it was in fact a determining factor in purchasing the reciever I purchased. Problem is, when I try to upscale my wii, it changes the aspect ratio to 4:3 and I have been completely unable to fix the problem. Its either correct aspect ratio and 480p or the wrong aspect ratio but 720p. I'm shooting for 720p upscaled with 16:9 via the wii, and hopefully if you guys can direct me to hooking up the cable tv.. that as well!!
hope this isnt asking too much, im tryin tryin tryin to learn!
) and use its tuner & audio/video output into the Onkyo.
