I am new to home audio systems so I'd like some suggestions on what components would be the best to use, to do the following:
I have 6 rooms I'd like to have music available to via one receiver. I'd like each of the rooms to have the ability to adjust the sound as well as the ability to change sources. Probably between the radio and a CD, however if it is possible to also have each of the rooms listen to different cds (via a cd changer) or different radio stations, then that would even be better. The only way I see that happening though is if I have multiple cd/radio receivers as inputs.
I would like to accomplish this for the smallest price that I can, so nothing to big please. Basically, just let me know what you would do (what components, accessories, etc. you would use) if you were building this system.
