Hi
I would be interested to know how to solve this problem I have about sound.
I have Sony SS-MB200H speakers with a Sony STR-DE310 Stereo Receiver and one speaker stopped producing sound while the other one is fine. I have replaced the wire on this and this is the second time its stopped producing sound. Would this be because of the wire I am using? Its the cheap stuff found at Big Lots/Wal-Mart which are longer than my Sony supplied original wires so I put these in a better position than keeping them close to the Receiver which is impossible to do as I am in a small apartment in the midst of finding a new residence. I mean its better to have the more out of the way, so I'm using the longer cord though one wire is in the way of where I walk so would that have helped in not producing sound because the wire seems secure at both the speaker and receiver ends or its it because its a cheap wire and I need some more pro.
Any Suggestions would be well appreciated.
I just thought you people would know because I've been reading posts here off and on for awhile and find it very helpful
Thanks!!
UPDATE:
I can use both speakers now just that one is lower in volume than the other and have used the balance knob to verify it so it seems if I put both speakers in A/B Left instead of using R/L A and have both A and B sets used it works so it seems the low volume is only the Right output on both A and B sets of speakers and I can't seem to find anything on the internet that helps so if any one knows what's going on please help. I'm guessing something is wrong with the Receiver and needs to be fixed somehow. Thank You.
Thanks!!
UPDATE:
