Home Theater Forum  ›  Forums  ›  Other Diversions  ›  After Hours Lounge  ›  Are Mortgage Rates Going to Go Lower ? (than they are today).
#1
Rating: 0
I have a 6.5% fixed 15 year mortgage. I can refinance at 5.175% with a 15 year fixed rate mortgage with no points. I have until 9:30 AM tomorrow to lock in the 5.175% rate.
Do you think that mortgage rates will go down any further before May 28th?
Thanks In Advance
Export to Wiki
#2
Rating: 0
Re: Are Mortgage Rates Goinng to Go Lower ? (than they are today).
Everybody was expecting one point cut today, but got only three quarters. There's definitely going to be more cuts and some even predicts Japan style ZIRP( zero-interest-rate policy) in future.
This may not translate to mortgage interests as low as couple years back(think sub prime), but it will go definitely lower than what you are talking about. It is a 'necessity' for feds to have the mortgage interest rate to go down.
JMHO
Export to Wiki
#3
Rating: 0
just my $0.02 - while I know the Fed wants lower mortgage rates and increase spending, at some point their rate cuts are going to most likely cause inflation or at least a big fear of inflation - at which case the rates will rebound.
Export to Wiki
#4
Rating: 0
The Federal Reserve doesn't cut mortgage interest rates-- nor do they even directly influence them.
Today's cut by the Fed will not necessarily translate into lower rates. The Feds cut the discount rate-- what it charges banks to borrow directly from the Fed. The Feds also lowered their federal funds rate target to 2.25% which is a short-term rate that banks charge each other for overnight loans.
These rates have nothing to do with long-term mortgage rates.
Long-term mortgage rates are mostly tied to the 10-year Treasury yield. That is determined by bond traders, worldwide. Meaning mortgage rates are determined more by how fearful the market is of inflation. Right now that's a pretty big fear.
So don't be surprised to see rates rise as they have been lately -- even though the Feds have been cutting short-term rates.
Watch the 10-year Treasury yield if you want to see what long-term mortgage rates will do. Long-Term mortgage rates are typically about 2 percentage points higher than the yield on the 10-year Treasury, which currently is about 3.29%. However, lenders are so skittish about lending money right now due to the turmoil in the housing market that long-term rates are more than the typcial 2 percentage points above the 10-year Treasury yield.
Export to Wiki
#5
Rating: 0
You also should consider the closing costs, compare to the time you will spend in the home and the time value of money.... It can be complicated. Generally a 2pt decrease in rate pays off your closing costs in 4-7 years... Yes - it takes that long to break even.
Martin Luther observed that the human race is like a drunkard who falls off his horse on the left and makes up for it by falling off the next time on the right.
Export to Wiki
#6
Rating: 0
Bryan,
Never said the feds cut mortgage rates.........
Normally, when the Federal Reserve cuts the rate at which it lends money to U.S. banks, those banks in turn cut the rates at which they lend money for personal and commercial use.
To the OP:
A Fed rate cut could send some mortgage rates even higher: Financial News - Yahoo! Finance
Export to Wiki
#7
Rating: 0
Quote:
This is a very important point, and one of the most important points to consider when refinancing.
Export to Wiki
#8
Rating: 0
Misinterpreted your post where you said "It is a 'necessity' for feds to have the mortgage interest rate to go down." Since the Feds don't control mortgage rates, that threw me off. My bad.
Yeah, they cut the rates on short-term personal and commercial loans. Not necessarily long-term rates. Those follow the 10-year treasury yield. So yes, banks will probably cut some rates, but more than likely it will be on ARMs and other short-term loans, not 15 year fixed-rates the OP was asking about.
Export to Wiki
#9
Rating: 0
Those would be some pretty serious closing costs! If you take an example of a $150k mortgage over 15 years and use 7% and 5%, the monthly payment would be reduced by $162. So you would save >$1900 in the first year. If you use the same numbers with a 30 year mortgage the change is even more drastic since a larger portion of your payment is interest. ($192/mo vs $162/mo)
Export to Wiki
#10
Rating: 0
Does anyone have any experience with online mortgage companies like Lending Tree or Quicken? We were thinking of going with our present bank, SunTrust, but have also considered these.
I know enough to know I don't know enough!
Export to Wiki
#11
Rating: 0
I have not used Quicken Loans directly online, but have gone through Rock Financial locally. They are a "Quicken Loan Company" and all documents are processed as Quicken Loans. They have been the best mortgage company I've ever worked with. We've used them for two refinancings and one condo purchase, and all three closings went smoothly. I've had some bad experiences with other mortgage companies and brokers, so I do not hand out praise casually.
My DVD Collection
My Equipment List
My Photo Gallery
Export to Wiki
#12
Rating: 0
Re: Are Mortgage Rates Going to Go Lower ? (than they are today).
Scott, who did you deal with from Rock? I have a friend that works in your area for them. His name is Chris and we are thinking of going to him for a new loan soon.
http://www.verorakeback.com/
Play online poker? Get the most rakeback at my site!
Export to Wiki
