Home Theater Forum  ›  Forums  ›  Home Theater  ›  Members Theaters and HT Projects  ›  need advice on a fixed frame screen
#1
Rating: 0
I will be purchasing the Sony VW40 FP. It will be placed on a shelf on the rear wall appr. 15.5 ft away from screen. This is a very dark room but I'm concerned about which numbered gain I should get on a 92 inch fixed frame. Any advice would be beneficial, thanks.
Export to Wiki
#2
Rating: 0
Re: need advice on a fixed frame screen
I built my screen with plain, white blackout cloth for Hancock Fabrics. Other fabric stores around the nation sell the exact same thing. In a totally dark room the screen is more than bright enough using a Panasonic AE-900U. I plan on experimenting with paint formulas. Specifically the Black Widow formula.
-Robert
Export to Wiki
#3
Rating: 0
A fixed frame screen is exactly the look I want for my ht. I'm just not sure what gain is appropriate considering my situation.
Sony VW40
Throw-15.5 ft
rear wall shelf
light controlled room
I hear a high gain grey is good for DLP but this is Lcos and I can't seem to find info on what screen gain goes good with this projector and my set-up.
Export to Wiki
#4
Rating: 0
That is a technical question best answered in the Display and Projector section.
-Robert
Export to Wiki
